Hi all-
Just a simple build question, I hope- working on an F1 Rocket rudder...
I've got a bottom rib with holes that seem to be pretty close to the edge. I drilled through the pre-drilled holes in the bottom rudder spar reinforcement plate into the rudder spar, rudder horn and bottom rib.
http://s71.photobucket.com/albums/i1...der_rib1-1.jpg
Looks like the bottom rib flange has 6/32"ED - 5/32"ED, when it should be more like 8/32" minimum.
Can I just put two more holes inboard, through the rib, spar, horn and doubler plate? How far inboard should I put them if so?
Hope that (newbie) question made sense...
Thanks.
-Barry
