...plausible, unfortuneately.
My Tiger factory rebuilt O-360 engine - with new cylinders and the "new material" guides - failed the wobble test on two cylinders at 600 hours.
The variation seems to be very engine/airframe dependant, and I have not really heard a good explanation of exactly why excess wear occurs, as opposed to failing on the low end, which would be a symptom of pending sticky valves.
I would just perform the test at 50 or 100 hour intervals and track the readings.
If you are using the real Lycoming fixture, as opposed the the Aircraft Spruce substitute, the test is quite non invasive since the fixture pushes the valve down as it is is tightened.
This is what the Lycoming fixture looks like -
Most will have been modifed to use a dail indicator gauge instead of the specified feeler gauges.
Lycoming has some info around on operation to reduce valve guide wear...
Originally Posted by Thomas Lukasczyk
Hi all
I did the Exhaust-Valve wobble test (Lycoming SB388c) yesterday and all clearances turned out to be within the specified numbers.
However, both rear-cylinders almost reached the maximum allowable clearance at a reading of 0.025 and 0.028. According to the paperwork, this engine has
only 400 hours on the meter. Are these values plausible for a "low" time engine or do they necessarily indicate a "high-time" engine? How does the valve-guide wear over time?
Is it just getting worse as your hours build up or does most of the wear occur during break-in?
Obviously there is a minimum clearance to determine carbon build up. So what would be the wobble-test reading on a brandnew cylinder?
Thank you very much for your experience
regards
Thomas, RV-4
http://www.rv-4.de/
