Installing A New Spinner
After I installed a new Catto 2 blade prop I need to build a new spinner. I think I can use the same forward and main spinner bulk heads as the prop thickness is the same as the Catto, in fact I used the same bolts.
How do I locate the existing screw holes in the new spinner? Can I do this by leaving the prop on the plane? I'm trying to wrap my mind around how to cut the new spinner. Any advice / tips would be greatly appreciated.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
