Old 04-05-2009, 07:18 PM
flickroll's Avatar
flickroll flickroll is offline
Default Dynon Tach Settings
Today I finally was able to fire up my mag driven Lycoming with Whirlwind 200RV prop and shaaazzzaaammm.....what a nice sound that was. Looked at the tach I sez to myself...man this thing sure idles sweet at 340 RPM. Then it occurred to me that the tach must be off. I changed the 'pulses per rev' setting from '2' to '1', and now I THINK it is reading correctly. So....before I invest in an optical tach to validate the Dynon reading.....what have others set the 'pulses per rev' setting at for a mag driven O-360? Oh yeah, I need to add this smiley.... Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 04-05-2009, 09:48 PM
guccidude1 guccidude1 is offline
Default RE: Dynon tach settings
Yeah, I had to set my D180 on "1" to get the O-360 RPM right. Dan.
Old 04-06-2009, 08:13 AM
breister breister is offline
Sounds like you use Magnetos.
Although a Magneto fires twice per revolution, every other pulse is negative vs. positive. The Dynon only counts the positive pulses.
