Old 04-05-2009, 04:12 PM
db8's Avatar
db8 db8 is offline
Default Sniffle valve placement
I have the newer Surerior Sump. Does it matters which of the two holes (on the bottom of the sump where the four intake tubes come together) that I use for the sniffle valve and the manifold pressure hose? Can't call them and ask Thanks. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 04-05-2009, 05:11 PM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default Here what I did
The sniffle valve is located in the hole closest to the prop. My manifold pressure comes off the top of the engine (cylinder head) at the rear of the passenger side, not the sump.
Old 04-05-2009, 05:25 PM
mannanj's Avatar
mannanj mannanj is offline
Default Sniffle
Don't know which sump you have. If one hole is aft of the other, I would place the sniffle valve in the most aft hole for a tail dragger.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 04-05-2009, 05:53 PM
db8's Avatar
db8 db8 is offline
Default I agree
Mannan. Did some more research and I agree with you, especially since it is a tail dragger (to use the aft most hole). Not as critical on an "A" model I don't think Andrew. Thanks. Dave
Dave Buntin
Old 04-07-2009, 03:20 PM
Mike F's Avatar
Mike F Mike F is offline
Actually, you can. I called them today to ask if their sump would fit on an ECI engine. Tech support was there and was very helpful. He said they'd be there until everything was sold.
Mike Ferrer
A&P/IA - North Texas Avionics
RV-7 QB - Finish Kit / N772RV <Sold>
Hicks Airfield T67
Fort Worth, Texas
--- and sometimes ---
Pittstown Point - MYCP
Crooked Island, Bahamas
2014, 2015, 2016, 2017. 2018 DUES PAID
