Old 04-03-2009, 06:43 PM
vonjet vonjet is offline
Default Plane Power Alt Question
Ok here is the background:
I have a Plane Power Alt with built in Regulator. I do not have a split master. Only Master switch.
When I have the Master on and I'm messing with radios and such in the plane I noticed that the aluminum pulley on the alternator gets pretty warm.
Why is this? And is it normal?
To avoid this can I just pull the 5amp alt field breaker while working with the avionics and master on?
Bryan
Old 04-03-2009, 07:19 PM
AltonD's Avatar
AltonD AltonD is offline
My plane power alternator is pulling 5-6 amps with the engine off. It is doing everything it can to maintain the bus voltage.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 04-06-2009, 11:48 AM
Default I'll answer this
I called Plane Power and got the answer:.
It is normal for the pully to get warm while having the master on if you dont have a split switch. According to Plane power it wont hurt the altnernator and if you dont want to to get warm you can pull the 5 amp field sense breaker while working on your avionics.
