Old 04-03-2009, 09:49 AM
Adam Oke's Avatar
Adam Oke Adam Oke is offline
Default DRDT-2 Table
Well,
I've got some cash flow again, and I will be back to work in May ... so it's back to the Tool Department and Workshop Upgrades before the big order come September! I will be building an independent DRDT-2 table using the same design as EAA tables with slight modifications. I want to build a removable 'Bed' on top of the surface.
My question out to everyone: Is the blueprint that comes with the DRDT-2 sufficient in size .... or did you wish you had made the top surface larger?
My plan to have the bed removable and not permanently fixed to the table, so that I can use it for other things if necessary.
Adam D. Oke
Old 04-03-2009, 09:57 AM
gpiney gpiney is offline
I built the table to the plans provided with the DRDT-2. To date, it has been sufficient for everything except the big skins. They are a 2-man job.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
Old 04-03-2009, 09:59 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
Stock size worked well for me. It was a nice compromise between usability and portability.
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 04-03-2009, 11:06 AM
Dave Cole's Avatar
Dave Cole Dave Cole is offline
Default I built the table to plans...
And I would do the same if I did it again. When it came to large sheets, I put cardboard boxes on the work table on either side of the DRDT and used the boxes as outboard supports for the overhanging end of the sheet.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
Old 04-03-2009, 02:45 PM
Adam Oke's Avatar
Perfect. Thanks for the input.
Adam D. Oke
Old 04-03-2009, 04:09 PM
Righty Righty is offline
Adam,
I built my DRDT-2 table according to the plans. The plans are ambiguous as to the width of the table. Basically, they say to build it as wide "as needed". I didn't want to build a dedicated table that would take up shop space for something that is not used frequently, so I built it relatively narrow, about 3 feet wide overall. The table is placed on my large workbench when I need to use the DRDT-2 and stowed out of the way at other times.
In my view, this table would be inadequate on its own. So, I built an 'auxiliary' table that I set on either side of the normal table as needed. I like that I can move these two tables out of the way when not in use. It also comes in handy to be able to move these two tables around on the workbench when I am using the dimpler.
Basically, you will need to choose between:
1. Building a very wide dedicated table. This can be done as you described to create a multipurpose table that the dimpler can be removed from. Not helpful if you don't have the additional space and already have a large workbench otherwise.
2. The DRDT-2 can be embedded in an existing workbench such that it can be removed when not in use and a plug of sorts placed in the hole left by the DRDT-2 to allow the workbench to be used normally. The downside of this might be complexity and creating a support surface that won't scratch your skins, but also serves as a workbench at other times.
3. Build a small table according to plans, place it on an existing workbench when needed and use something (cardboard boxes, a small auxiliary table, stacks of foam, etc.) to support large skins that overhang as needed.
Aaron Frechette
RV9A Standard Kit (wings)
Old 04-03-2009, 04:44 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default My portable solution
I didn't want to mount the thing to a dedicated bench so I mounted it to an extra roll around cart I had. It works excellent! I have considered making some removable table extensions for the larger pieces. The outboard wing skins I did solo with the extra running off the table to the workbench which is a similar height.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 04-03-2009, 10:12 PM
rzbill's Avatar
rzbill rzbill is offline
Default large dedicated table not required
It is true that the large skins need support over a considerable area. Instead of building a dedicated table this large attached to the DRDT-2, I suggest a smaller table is adequate as long as it is the same height as your main workbench. The DRDT-2 and its small table can be rolled up next to the main workbench to support a huge skin. It worked fine for me.
Bill Pendergrass
ME/AE '82
Old 04-04-2009, 06:43 AM
Bruce's Avatar
Bruce Bruce is offline
Adam,
You can go on my website listed and look for the dash-2 table I built
3 years ago. Works very well and can do all the skins and the -2 won't move on you. Two 4x4 tables with 2 carriage bolts that hold the -2 in a vise.
The -2 can be turned upside down and you can use the whole table to put stuff on that you can never find. Works great for me and loved it for the side skins and the bottom skins.
Take a look and hope you like it.
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
Old 05-12-2012, 11:58 PM
izzybear's Avatar
izzybear izzybear is offline
Talking Great Idea!
Don,
I love that Idea of putting the DRDT-2 on a small rolling bench. I would think that if I made the surface of the DRDT-2 table the same height as my EAA work benches, then I could roll it right in the gap between the two benches and they would be the left and right extension on both sides for the big stuff when needed. Thanks!! Searching the archives is a great education!
Jim
RV-8 N223GT (reserved)
Finish - arrived 10/7/15
Fuselage - arrived 3/14/14
Wings - arrived 3/7/13
Builder # 83331
www.mykitlog.com/izzybear
VAF Dues gladly paid up till December 2020
"The ultimate responsibility of the pilot is to fulfill the dreams of the countless millions of earthbound ancestors who could only stare skyward and wish." - Unknown
