Originally Posted by prkaye
Is it a big no-no to use a larger size ring terminal on a smaller post? for example a ground strap with a 5/16 terminal on a battery with a 1/4" post?
This will give much less surface area in the connection, which could increase the chance of that connection eventually failing due to high resistance. I would only do this for connections where you could live with the consequences of that connection failing.
If the main battery ground strap connection fails you will lose the whole electrical system. I'll let you decide whether that is an acceptable failure mode or not.
Personally, I would acquire the correct ring terminal.
