Originally Posted by N184JG
While out flying last night my max MP was 28.3 on take off local baro was 29.51 on ATIS we are at 720ft . I have a cold air inducton with an intake filter in the upper lift side of cowl. Could I do better or is this normal?
Remember the ATIS altimeter setting is for the sea level pressure to be set in the Kollsman window.
Lets assume your static MP (just sitting there not running) was 28.3.
(29.51-28.3)*1000ft/in = 1210' should be read on your altimeter.
Doing this in reverse, assuming 29.51 atis and your actual 720', I would expect 28.79" on MP static.
Can you tell us what the static MP was vs full throttle MP? That would help us.
edit. Hey I poked around and found this
nice site for you for reference. Its well laid out. Simple read and explanations of this.
