Old 04-01-2009, 11:04 AM
kbehrent's Avatar
kbehrent kbehrent is offline
Question Crossing over wires using TurboCAD
I'm using TurboCad 15 to layout my electrical schematics. I can't seem to figure out how when drawing a wire line over an existing line to get it to "jump" over so that it does not look like it is attached to that wire. Anybody know how to do it?
Thanks.
Kevin Behrent
TeenFlight Puyallup, President
www.teenflight.org
http://facebook.com/teenflightpuyallup
EAA Chapter #326
Puget Sound, WA
RV-9A
Aerosport (Superior XP) IO-320 C/S, Precision Eagle EMS
Old 04-01-2009, 11:19 AM
f1rocket's Avatar
f1rocket f1rocket is offline
IMO, that's not necessary.
First, to answer your question, I am not aware of an automated way to do it. You would have to create an object and then insert it when you need it.
Second, unless crossing wires have a dot or some other designation, it is assumed that they are not connected. At lease that's what I've seen others do. I've seen some drawings with the "jump" nomenclature and to me, it over complicates the drawings and doesn't necessarily add to the readibility.
However, it you want to jump them, that's okay too. They are your drawings so whatever helps you to read them is just fine.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 04-01-2009, 11:29 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Kevin...
Thanks.
...do you have my file of TurboCAD symbols?
I have sized the "dots" you need to show a connection. Too small a dot can get lost if the schmatic is reduced.
You need to be careful if you have 4 "wires" meeting. This is a snapshot of a portion of my symbols.tcw cover sheet.
If you always follow this convention, you will never need the "jump over" line option.
Here is a link to the full symbols sheet, all set on a 0.2 grid with reference points set in the proper place.
Credit to Bob N., but his originals in AutoCAD did not translate well into TurboCAD, so I redrew them, set up a better grid and defined text sizes. If you have your schmatic open at the same time as the symbols sheet, cut-n-paste is easy. Once an item is on the schematic sheet, I find the TurboCAD "Rubber Stamp" option to be the easiest to replicate stuff.
Link since original jpeg file is too wide for VAF - view it at 100% size --
http://i644.photobucket.com/albums/u.../symbols-1.jpg
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Last edited by az_gila : 05-12-2009 at 05:04 PM. Reason: added full sheet - improved link pic
Old 04-01-2009, 12:34 PM
kbehrent's Avatar
Thumbs up
Nice job on the Symbols! How can I get a copy of them?
Thanks!
Kevin Behrent
www.teenflight.org
EAA Chapter #326
Puget Sound, WA
RV-9A
Old 04-01-2009, 01:08 PM
az_gila's Avatar
Thumbs up Sent to your...
Thanks!
...regular e-mail account listed on VAF.
Gil Alexander
Old 04-01-2009, 01:23 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Crossing over wires
Thanks.
Is this what your wanting to do?
If so, Use the circle command and trim away what ever part of the circle and "jumping" wire in the direction you want to show.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 04-01-2009, 02:01 PM
kbehrent's Avatar
Thumbs up
Gil,
Got your email. I was able to get them loaded. Big Thanks. Check your email.
Carlos,
Thanks for the tip!
Kevin Behrent
www.teenflight.org
EAA Chapter #326
Puget Sound, WA
RV-9A
Old 04-01-2009, 03:04 PM
robpar robpar is offline
[quote=
If so, Use the circle command and trim away what ever part of the circle and "jumping" wire in the direction you want to show.[/QUOTE]
It has been years since I used TurboCad but I use the above method in AutoCad and then copy the result wherever I need it. There are macros that will do it automatically but I never did enough wiring diagrams to worry about writing one of those. This works just fine unless you are doing it professionally and then you would use a dedicated circuit program.
I like the "Jump Over" style as it is easier for me to read then crossing lines without a dot.
Bob Parry
Old 04-01-2009, 04:55 PM
chaskuss chaskuss is offline
Thanks.
Kevin,
I use AutoCAD 2000, but this suggestion should work the same on both. I create a semi circle and lay it over the "jump" intersection. I then zoom in on the jump area. Mark the area between one end of the arc and the intersecting wire. Highlight this section and use the delete command. Repeat the process on the other side of the cross wire intersection. This deletes the section of the jumping wire, between the ends of the semi circle.
Charlie Kuss
