Old 03-31-2009, 06:26 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Unhappy Does my stick really have to be vertical??
I think I've been bit by the dreaded "pushrod too short" problem....
I'm talking about the control column to pitch pushrod, the one under the floor. After a bunch of reading and worrying I built it to plans length.
Now it is installed, and if I max it's length out, I can get the sticks to about 86 or 87 degrees, not quite 90. Doesn't sound like much, but that difference results in the stick end being about 1" forward of where it would be at 90 degrees.
Where in the manual does it say the sticks should be 90 degrees? Should they be?
If the answer is yes, I'll be ordering a new pushrod, making it 1/2" longer than the old one.
Thanks for any info,
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 03-31-2009, 06:39 PM
Mel's Avatar
Mel Mel is offline
The stick can be any angle you want as long as you have full travel. I have mine adjusted as far forward as it will go.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I know that.... I ordered a new pushrod..
For that same reason.
L.Adamson --- RV6A
Old 03-31-2009, 06:44 PM
amilder amilder is offline
The plans don't show them vertical. See DWG 32, the one that shows the control systems. It doesn't give a precise angle but you can get it close. I assumed that was the neutral position when I put my short elev. pushrod in.
Andrew Milder
RV-9A finishing- canopy
http://andyrv9a.blogspot.com/
Old 03-31-2009, 06:51 PM
andyrv andyrv is offline
Default 2 pushrods for me
I built a second pushrod (longer) for mine. My concern was having more than half the threads engaged at both ends so it can't come out unless I want it to.
Andy
Old 03-31-2009, 08:11 PM
db1yg's Avatar
db1yg db1yg is offline
Hi Dave,
Do you have your seats finished? Do you have your seat cushions yet--or do you have access to a set of cushions similar to the ones you will have?
I did this to determine correct stick position--and btw, I was also concerned about the push/pull tube being too short:
I installed the seats and a set of cushions from a friends RV6a (thanks Mr. Hurd), sat in the plane making airplane noises, let my left arm rest across my left thigh, and noted the position of my thumb/index finger on the left hand. I adjusted fore/aft position of the stick so that the stick base was between the thumb and index. Then we made sure full deflection does not hit the panel nor the family valuables. In my case the perfect position ended up being slightly forward of vertical--which provided adequate rod end thread engagement. Flying RV friends told me that on cross country flights you end up flying the plane with the thumb/index fingers of your left hand at the base of the stick--in my case they were right and the positioning is very comfortable.
Hope this helps.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 03-31-2009, 08:29 PM
Rupester Rupester is offline
Default Not supposed to be vertical !
The sticks are designed to be canted forward at 5 degrees, IIRC. I had the same problem as you and called Vans. Gus set me straight. Once you know the intended forward cant angle, you'll find the p-rod length is dead-on.
Terry
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 04-01-2009, 06:16 AM
Dave Cole's Avatar
Dave Cole Dave Cole is offline
Default Sticks are not vertical
Like Terry said...they are not supposed to be vertical. Check the drawings and you'll see that the bottom portion of the stick weldment near the pivot point is at an angle to the stick. This part of the weldment is supposed to be vertical.
The stick itself will then be leaning forward.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
Old 04-01-2009, 06:24 AM
Jamie's Avatar
Jamie Jamie is offline
I had the same question on my -7. If I remember correctly the drawings have the stick centered over the center section. That's what I did.
Old 04-01-2009, 06:37 AM
pierre smith's Avatar
Default Yep, it's your call.......
..as far as comfort is concerned, as long as the minimum threads are complied with. Besides, you can bend the stick as well.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
