03-31-2009, 05:26 PM
100LL replacement may be here already...
This was just put up on Avweb.com today - looks like Continental is seeing the handwriting on the wall. Wonder how long before Lycoming starts the same testing to maintain their market share?
http://www.avweb.com/avwebbiz/news/C..._200048-1.html
Teledyne Continental said on Wednesday that it has just completed a round of flight and test-cell trials that suggest that 94UL may be an adequate replacement for 100LL, whose existence is threatened by continued availability of tetraethyl lead. TCM says it will push for approval of 94UL as the leading replacement for 100LL. 94UL is essentially 100LL without the TEL additive. It meets vapor pressure and other avgas specs, but without the lead, it doesn't match 100LL's octane, which is typical about 103 straight from the refinery.
But is 94 sufficient octane to avoid detonation on a hard, hot climb on a summer day? Teledyne said in a press conference that it hasn't expanded its testing into all corners of the flight envelope but four flight tests in a normally aspirated A36 Bonanza have revealed no cooling or detonation issues thus far. The company also said it doesn't think Full Authority Digital Engine Control (FADEC) will be required to make the engines run properly on 94UL.TCM has not, however, conducted a standard FAA climb-cooling test, which is the regime in which detonation usually occurs. Further, said Continental, it's not opposed to autofuel as a replacement for 100LL provided that certain standards are in place to assure consistent specs with regard to octane, vapor pressure and especially oxygenate additives such as ethanol. Although pure ethanol has been approved for limited use in modified aircraft engine in Brazil, it's considered a bad actor for aircraft use because it's strongly hydrophilic, lacks the energy content of avgas and causes corrosion in aluminum parts and degradation of soft seals and gaskets. High-octane autofuel does, however, meet basic octane requirements for normally aspirated engines. Owners who use it are finding it increasingly difficult to find autogas without ethanol blended in.
What about Continental's large-displacement turbocharged engines, such as the TSIO-520 and -550 series? Will 94UL work for them? TCM says stay tuned; it hasn't done the flight testing to confirm that. Others who have, however, have had difficulty passing the climb cooling barrier without encountering at least light detonation. TCM began its alternate fuel testing about a year ago and it plans to push for ASTM approval of 94UL as the transparent replacement for 100LL. That application will be submitted in a few weeks and could be approved as early as next fall. However, that's just the beginning of 94UL's journey to becoming a certified fuel, if it ever does. It will still require FAA certification and approval and at least a paperwork shuffle so that owners can legally use it in some airplanes. TCM's testing took place in an IO-550-B powered Bonanza, but it has done test-cell work with the 200-series engines, the O-470 and O-520 series.
03-31-2009, 06:19 PM
I am still pulling for Swift Fuel
All the Best ;-)
RV-8
RV-9 once the kids are older
03-31-2009, 06:37 PM
Isn't that essentially...
...the same as the certified Superior Vantage engine? Which is basically a Lycoming clone?
Data below from the FAA approved TCDS - check (Note 7) - which has the same CYA words as the Continental write up...
Fuel
Aviation Gasoline
ASTM D910, Min Grade
91/98 (lead optional)
Motor Gasoline (R+M/2) (See Note 7)
ASTM D4814, Min Octane 91 (no alcohol)
NOTE 7. Experience has shown that there is a higher probability of vapor locking on aircraft, especially on those equipped with fuel injected reciprocating engines when operating with high volatility fuels such as motor gasoline. Aircraft fuel system designs for the powerplant installation of these engines may need to incorporate special design features or enhanced cooling to accommodate operation with high volatility fuels such as motor gasoline. The aircraft fuel system hot weather testing requirements of FAR 23.961 must be successfully accomplished for each aircraft powerplant installation design of these engines (both carbureted and fuel injected) to obtain approval for operation with motor gasoline, reference AC 23.1521-1B.
...and Lycoming already approves 91/96UL in the O-360, which is a EU (Swedish?) fuel - Sounds similar to 94UL
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-31-2009, 08:36 PM
It's been there all the time on the data plate(91/96). Why now does anyone think this is new? (not you Gil)
03-31-2009, 08:59 PM
If it doesn't go faster I'm against it
If it doesn't go faster I'm against it. Surely there is a single real scientist in this world of formally educated and self educated experimenters that can come up with a fuel that can produce more performance from the engines in the world's piston engine aircraft fleet. If you read Jimmy Dolittle's book "I Could Never be So Lucky again" you know this approach has been around for quite a while.
Bob Axsom
03-31-2009, 09:06 PM
ho hum :)
I figured out about 800 hours ago that 87 octane works just fine.
There is one thing about Swift fuel thats a minus... its made from sorghum, and its seasonal, so they can't get enough of it to make it in the winter months.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
03-31-2009, 10:36 PM
Ho hum here too
Haven't tried 87 octane (EI's extend max timing out to 38 degrees BTDC I think) but I use 91 octane with and without ethanol.
My airplane hasn't seen 100LL for 500 hours
Discalimer..I have wingroot mounted fuel pumps only!!!
Frank
04-01-2009, 01:46 AM
No..the FAA approved...
...91/96 on the data plate is for leaded fuel with 2 ml/gall of TEL (lead)
Not the same as the UL stuff...
Only slightly OT
This is a picture I took last month of the source of all of the TEL on our 100LL.
It's the refinery/chemical works in Port Sunlight, Cheshire, England, taken from across the River Mersey (the one from the 60's song...  ...)
The typical English winter weather shown is a little different from the usual Tucson weather.
If this place burns down, or blows up, most of us will be in deep flying doo-doo...
Gil Alexander
04-01-2009, 07:33 AM
This is great news!
I've been saying this for years -- the solution is just remove the lead. The resulting fuel is safe for 80% of the fleet and costs a dollar less per gallon -- and will get even cheaper over time because any refinery can make it and any pipeline can carry it.
Anyone who NEEDS 100 octane can already buy unleaded 100 racing fuel just about anywhere in the country. When 100LL goes away, Lyc and Cont will certify it for the few engines that need it and the big airports will start to carry it.
And finally, the few people who think they actually need racing fuel will be the only ones who have pay for it.
I can't wait.
Jon Baker
RV6A sold, RV4 in-progress
Houston
04-01-2009, 08:32 AM
Frank
I have an Electroair, and have a timing meter set up to monitor it. The only time the timing falls below 25 degrees is at reduced manifold pressure settings (below 17"), and you typically don't see that until you're above 12K. At that point you're at 50% power or lower anyway, so its next to impossible to hurt the engine.
N8155F C150 flying
