Old 03-31-2009, 10:35 AM
niblettda niblettda is offline
Default Horizontal Rear mount Carb?
I've found a Lycoming O-360 engine with a horizontal REAR mount carb. Safe to say, I've never seen this before. Is this something that would fit in a RV7/9? I'd have to think that it would really make it easy to smooth out the cowl.
Sadly it's not a constant speed prop, but it just got me thinking.
David Niblett
RV-9A QB
http://www.n396dk.org
Old 03-31-2009, 04:51 PM
chaskuss chaskuss is offline
David,
Sounds like you've got an O-360-A4x out of a Grumman. I can't answer your question directly. I'm building an 8A, not a side by side model. Worst case, you'd have to buy a sump and intake tubes off of a vertical or forward facing (Angle valve 360 with forward fuel injection) engine. AERO also sells a kit for converting vertical and rear facing systems to forward. It's pricey. See
http://www.aeroinstock.com/products/...cat/index.html
I'll bet that Mattituck also carries those sumps. Check with them too.
http://www.mattituck.com/
You can also find them used (off of Mooneys) on EBay occasionally.
Charlie Kuss
Old 04-02-2009, 11:40 PM
osxuser's Avatar
osxuser osxuser is offline
I know it won't work on an A model, I can't speak with certainty for the others. However, I believe you can modify the rear load sump to become a front load with minimal effort.... Not positive of this by any stretch.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 04-03-2009, 12:11 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation I don't think works..
...on the O-360-A4K (Grumman Tiger) and similar Lyc. models.
The casting for the internal intake tubes does not connect to a front face flat like some of the IO models, IRRC.
The sump/intake tubes change should work though, and the HA-6 carb will have a fair value.
The O-360-A4K - if that is the model you are looking at - also has the solid crank mentioned in a previous post. Constant speed would require an electrically controlled MT prop.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-03-2009, 06:18 AM
Thanks osxuser and as_gila, that's what I was really trying to figure out. I didn't think it was going to work in the 9A, but I was hopeful. It would be a nice set up to make a nice smooth cowl bottom if I could figure out how to get the carb around the gear mount. (I'm assuming that is most likely the problem.)
Thanks for everyone's help!
David Niblett
RV-9A QB
