03-31-2009, 09:58 AM
Distance between tubing supports
Does anyone have a reference for the maximum allowable distance between aluminum tubing supports? I didn't see it during a quick read of AC 43.
Thanks for the help,
-DC
03-31-2009, 10:04 AM
Senior Curmudgeon
More info please
What kind, and size tubing are you asking about???
What is its function, I.E., brake line, gas line, pitot line???
My elevator pushrod is alum tubing, over 8' long, and not supported except at the ends.
Yes, extreme case, but hopefully you see my point.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
03-31-2009, 12:57 PM
Tubing is 5052-O 1/2" OD, .049" wall. Service is hydraulic tubing at 1200psi.
This is a certified application, so it would be nice to have a reference to refer back to.
-DC
03-31-2009, 02:53 PM
It seems to be...
-DC
...every 19 inches (maximum) for 1/2 inch alum. tubing per FAA AC 65-9A. It's in Figure 5-24.
The document is on-line at the FAA web site, you probably should print out the table and give it to your IA for the 337.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-31-2009, 02:56 PM
Found the answer in Fig. 5-24 of AC 65-9A (page 119).
For 1/2" OD aluminum tubing, the maximum spacing of clamps is 19".
For future ref (OD, spacing)
1/8, 9.5"
3/16, 12"
1/4, 13.5"
5/16, 15"
3/8, 16.5"
1/2, 19"
-DC
03-31-2009, 02:57 PM
Man, we must have been typing at the same time!
