03-30-2009, 04:25 PM
Hartzell Blended Prop (painting)
Does anyone know the procedure on painting a perfectly good
prop.
I want to paint mine gloss black to match Jay Pratt's RV-8.
Who can paint it in the DFW area and cost if possible.
Thanks in advance
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
03-30-2009, 04:55 PM
If it's of concern....
One thing to be aware of, Bruce. Does this prop have a type certificate? If so, it will no longer be certified if you paint it with anything other than what the type certificate calls for.
Prop manufacturers are pretty picky about the finish on their props.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
03-30-2009, 05:45 PM
And to be more specific...
...that would be Sherwin Williams Polane paint.
This Hartzell kit is stated to be enough for 8 gray blades
Kit No. A-2742 Paint Kit. Gray (Quart) includes:
8 fluid ounces Catalyst (CM30)
4 fluid ounces Accelerator (CM31)
16 fluid ounces Polane Reducer (CM32)
1 quart Paint, Polane, Gray (CM34)
16 fluid ounces Wash Primer (CM24)
16 fluid ounces Reducer, Wash Primer (CM25)
4 fluid ounces Acid Diluent (CM26)
I believe this is the same paint that Sensenich wants you to use too...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-30-2009, 05:59 PM
Gray
And I believe that "gloss black" is not an option.
03-30-2009, 06:45 PM
For what its worth Hartzell will paint your prop for you just costs 900 bucks but they will do it.
I was told that black with yellow tips is OK with Hartzell, they even told me if Vans asked them to they would offer that as a option when buying a prop
All the Best ;-)
RV-8
RV-9 once the kids are older
03-30-2009, 07:02 PM
That's good news.
I didn't know they would do that.
03-30-2009, 07:55 PM
painting a prop
I just had my Prop painted, Let me back up, They stripped the old paint, alodined it reprimed, painted and balanced it. I priced the paint and the cost came in at $94. I called H and H props in Burlington NC. I gave it to them on Tuesday and picked it up on Friday of the same week. Their cost was
$150.00. Shop around but go to a prop shop
Tad Sargent
7A
03-30-2009, 09:12 PM
Boomer,
Check with Byam Propeller at FTW. I don't know if their prices are what you had in mind, but I do know they do good work.
Glider
Pat Tuckey
RV-8
Superior IO-360, Hartzell blended airfoil, GRT dual screen EFIS
Flying 1400 hours
Formation Acro SAC Card
FFI flight lead
25XS (Waxahachie, TX)
03-31-2009, 08:23 AM
Mel is correct, the factorys call for specific paint products when painting propellers, we had to get a special processes procedure through the FAA to be able to do the designer propeller process.
James A Dean
Chief Inspector
American Propeller Service
www.ameritech-aviation.com
03-31-2009, 09:05 AM
Question?
I don't want to steal this thread, but a couple of the responses got me to thinking. Since you are bolting the prop onto an experimental engine, isn't the prop no longer certified at that point unless a prop shop yellow tags it? I am under the impression that you cannot simply pull the prop off your experimental and then sell it as a certified prop. Is that a true statement or not?
If it is true, then I wouldn't worry so much about "certified" colors, etc. Go ahead and use the paint that the manufacturer suggests but as long as you have the prop re-balanced once it's done, you should be okay. It might have an effect on the warranty though, if it's still in force.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
