Originally Posted by Mel
Garmin web page shows the 327 to be more than 1/2" longer than the 320, so I doubt they will use the same tray.
...which is a great source of information says this in their FAQ....
Yes, the GTX-327 utilizes the same mounting rack and mating connector as the GTX-320 and GTX-320A. The GTX-327 offers a few additional features but matches the standard connection pins as the GTX-320 and GTX-320A.
If you check the Installation Manuals for both transponders you can see that Garmin changed how they measure the depth behind the panel....
The two transponders have
identical dimensions on the depth of their mounting trays, so the SE Aerospace FAQ does now make sense.
The link to the great avionics resource --
http://www.seaerospace.com/
