Old 03-27-2009, 03:14 PM
almarsh almarsh is offline
Post Static system
this plumming system for static sys. micky mouse , would like any ideas the rivet idea and attach static line to is crazy i saw a clever port idea someone had but dont no where to get it , it does away with little rivet stem idea to attach line to anything will help..
Old 03-27-2009, 03:29 PM
Mel's Avatar
Mel Mel is offline
Default Van's (rivet) static system.
Mickey Mouse as it may be, literally thousands of RVs have been flying successfully with it for many years. Mine has been flying for 16 years. Never had a problem.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-27-2009, 03:32 PM
jthocker's Avatar
jthocker jthocker is offline
Default static ports
3 RV8's with this system, using Dynon equipment, 3 identical airspeeds when flying formation and verified accurate using triangular GPS runs.
http://www.safeair1.com/PS_1.htm
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 03-27-2009, 04:31 PM
Default static
thanks for the site just what i needed
Old 03-27-2009, 06:22 PM
jthocker's Avatar
Just to back up Mel, the Van's method also worked for all my previous airplanes. You can't go wrong with either one.
Jon Thocker
Habitual Offender
