Old 03-27-2009, 10:26 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default Alternator Belt tension adjustment
Can seem to find any info on how to install/tension the alt belt. Does anyone have any insight/tips?
Thanks!
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 03-27-2009, 10:41 AM
jthocker's Avatar
jthocker jthocker is offline
I believe the correct tension is reached when it takes 12 ft/lbs. of torque to spin the alternator pulley while holding the prop.
Mel??
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 03-27-2009, 10:56 AM
Kevin Horton's Avatar
Adjust the tension arm so that 11?13 ft-lb (new alternator belt), or 7?9 ft-lb (used alternator belt) of torque on the alternator pulley is required to slip the pulley on the alternator belt (from Lycoming SI 1129A Accessory Drive Belt Tension).
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 03-27-2009, 11:19 AM
MS19087's Avatar
Default Thanks folks!!
Thanks for your quick replies - lining up some odd jobs this weekend!!
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
