03-27-2009, 10:16 AM
Bonaco Hose / Brake Lines
I am considering using the Bonaco hoses/lines. Is there anyone else out there that has used them on RV's
Thx,
03-27-2009, 10:22 AM
There are a bunch of us.
I had Brett make up some flexible fuel hose to go between the selector valve and electric boost pump for my RV-8 project. He was great to work with. He's currently making up another fuel hose for my engine compartment. Check in the reviews section of the forum and go back a while. There's more information there.
Craig Schwartz
RV-8 (Flying!), IO-360B1PC2 (180 hp, 1 P-Mag, 1 Slick Mag), Whirlwind 200RV, AF-3500, G496, Digiflight II, Classic Aero Sportsman Ultraleather Seats
N868RV
Santa Rosa, CA
03-27-2009, 10:34 AM
Craig, I'll do that thanks for the info.
Mark Malone
Houston,TX
RV7 Empenage
03-27-2009, 10:44 AM
Sorry Craig I'm new to the forum. I went back in the reviews and couldn't find a thing. do you know what the thread starter might be.
Thx.
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
03-27-2009, 11:02 AM
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
03-27-2009, 03:35 PM
Chad,
Did you get bigger snap bushing ( FWD of F704 ) if so what size ? I didnt know he also did FWF lines, I will be getting them also.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
03-27-2009, 03:41 PM
IIRC...those are 3/4" holes, and I bought a bunch of different sizes from ACS.
The FWF stuff is fairly new (within the last 8-9 months or so) from Bonaco. At Oshkosh last year, they were just starting to put together the "kit". I think I got one of the first sets back in October.
Chad Jensen
03-27-2009, 09:29 PM
Another plug for Brett. I got brake (gear leg) and fuel lines and they are wonderfully easy to install and Bonaco was quick on the delivery of exactly the length/diameter etc. that I wanted. If you use the gear leg brake lines, I recommend going with standard fittings on the end, but the smaller ID lines so they fit easily under the fairings. Brett can provide more info.
greg
Greg Arehart
N 7965A
03-28-2009, 11:14 AM
Hey all,
Thanks for all the great posts. I'll give Bret a holler when I get a little closer.
Mark Malone, RV7
N442MM reserved
