Very Important: Tires and Tubes
VERY IMPORTANT - TIRES & INNER TUBES
Last year I purchased two tires and inner tubes.
15 x 6.00 -6
The Inner Tubes that were sent are 15 x 6 600 -6. THESE are 2" bigger than what they should have been. The numbers look very close.
Yesterday when I talked to the distributor, he mentioned that he has been selling the tires and inner tubes this way for the past two years.
When I talked to the factory, he mentioned that if you have any folds in the inner tubes this will cause a weak point and failure.
Unfortunately, you really won't see the folds until you disassemble the tire after use.
MAKE SURE THAT THE INNER TUBES MATCH THE TIRES..!!!
