Old 03-25-2009, 02:31 PM
N999BT N999BT is offline
Default Can I use a handheld for DME?
Maybe some of you more experienced instrument pilots can chime in here. In its infinite wisdom the FAA has decided to change the approaches at my home airport (KCOE) to require either DME or ADF. I don't think I can legally fly an instrument approach into Coeur d'Alene anymore. The old ILS 5 approach is now the ILS or LOC/DME RWY 5, there is a RNAV (GPS) RWY 5, VOR RWY 5, and VOR/DME RWY 1. The ILS approach has no way to identify the FAF other than DME, the VOR 5 approach has DME or ADF required, the VOR/DME RWY 1 requires DME, and of course the others require a certified GPS.
So, can I legally fly the ILS approach using a handheld GPS for DME? I currently have an SL-30 nav/com and a 496 for navigation and GS, along with a backup 195.
Brent Travis
N999BT
Flying
Old 03-25-2009, 02:51 PM
morlino's Avatar
morlino morlino is offline
Nope. Actually, it's my understanding that you can't even use a panel mounted IFR GPS to substitute for DME; if the name of the approach contains the letters DME then you actually need DME to fly it. Of course, I'm far from an expert on this - I'm currently studying for my instrument written....
mark
RV7 - working on wings (very, very slowly)
Old 03-25-2009, 02:56 PM
scard's Avatar
scard scard is offline
Originally Posted by morlino View Post
Nope.
Agreed.
I disagree here. You need the stated equipment (DME) if it is in the approach Title. Otherwise, you may substitute IFR GPS if the position, fix, or whatever is pulled from the database. Example: If the approach is a VOR/DME approach title, you need both. If it is just titled VOR approach, but has available fixes in it that are based on DME or NDB or whatever, you may substitute IFR GPS for those points if you load them from the database. Clear as mud now I'm sure .
Yeah, it looks like you are out of luck without DME or IFR GPS.
Scott Card
CMW E-Lift
Old 03-25-2009, 03:04 PM
RVFlyer RVFlyer is offline
Default Sorry
In a word...no. It isn't legal. Like many things in aviation it may be safe but it isn't necessarily legal. As a CFI I usually find myself saying the opposite "just because it's legal, doesn't mean it's safe". This is different in my opinion. I've flown behind many crappy DMEs but rarely has my GPS given me a concern.
Another consideration... I don't think it would even be an issue unless there was an accident. At which time, your DME will probably be the least of your concerns.
Tom Chandler,
AOPA Regional Manager - Central Southwest
RV-4 bought it, sold it, bought it back, storm totaled it
ATP, CFII
Old 03-25-2009, 03:45 PM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
Originally Posted by scard View Post
Otherwise, you may substitute IFR GPS if the position, fix, or whatever is pulled from the database. Clear as mud now I'm sure .
I hate to jump in with a "me too", I totally agree with Scott here, as long as the fix referenced in the DME portion of the approach is pulled from the database of the IFR GPS, and not a waypoint which has been added by you, yes, the IFR GPS can be used in lieu of DME.
Sorry, the 496 cannot be legally substituted and can only be referenced for situational awareness.
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
Old 03-25-2009, 05:09 PM
morlino's Avatar
Smile Yeah, clear as mud
Actually, you said what I was trying to say. If the approach plate says DME in big bold letters in the upper right corner then you need it. If I didn't need to write code I would pop the semicolon key off my keyboard
mark
Old 03-25-2009, 05:29 PM
scard's Avatar
Roger. Now that I read again, I agree, you were on the right track. I think too many of us (me included) have written too much code such that we stop at the semicolon .
Scott Card
CMW E-Lift
Old 03-25-2009, 06:09 PM
BillSchlatterer BillSchlatterer is offline
Default Can substitute GPS but handheld is a problem !
AOPA pushed this through a long time ago.
Effective July 16, 1998, pilots may substitute IFR-certified GPS receivers for DME and ADF avionics for all operations except NDB approaches without a GPS overlay. GPS can be used in lieu of DME and ADF on all localizer-type approaches as well as VOR/DME approaches, including when charted NDB or DME transmitters are temporarily out of service. It also clarifies that IFR GPS satisfies the requirement for DME at and above Flight Level 240 specified in FAR 91.205(e). This approval represents a major step toward removing the need to retain DME or ADF in our cockpits for any reason.
Handheld is still a problem.
Bill S
7a finishing
Old 03-27-2009, 09:10 PM
morlino's Avatar
That's interesting Bill. After some searching I found this link to an AOPA page that has the information you mentioned.
Anyway, it seems to contradict what I (and apparently other people) learned in ground school. I'd be happier if I could find some mention of it in FAR 91 Subpart C or 1-1-19 of the AIM. Is it there and I just don't see it?
mark
Old 03-27-2009, 10:12 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
You just don't see it. It is in 1-1-19, sub paragraph f. Use of GPS in lieu of ADF and DME. My AIM is a little old, 2007, but I don't think the location has changed.
Jerry
N84JE RV-8 325 hrs doing second condition inspection.
