Take any float problem seriously. On my Maule I had the engine quit when powering back abeam the runway due to a stuck float which then flooded the engine at the low power setting. It gets your attention. If you have any doubts rebuild the carb and insure you have a good float. There have been float AD's based on plastic floats that absorb fuel and sink. Water from alcohol in auto fuel or any water that settled in the bowl could corrode the mechanism and cause it to stick. By the way, my O-360 had only 500 hrs on it and was overhauled by a top name shop. The engine was 5 years old.
Anyway, the point is to take symptoms seriously!
Tom Agin
Port Orange, FL
QB RV-8 completed!!
XIO-360-M1B with LASAR
GNS-430, GI-106A, GTX-330, 9000EX, Becker 4201, Digiflight II VSGV, ADI, Dynon Dlight Dek 180, Vertical Power VP-200
