Old 03-24-2009, 08:12 AM
tomhanaway tomhanaway is offline
Default 3 blade prop and lower cowl removal
Does anyone have any suggestions or pictures of how they handled the cut on the lower cowl to deal with removal of cowl and position of 3 blade prop and front landing gear leg. .
Tom H.
Old 03-24-2009, 08:38 AM
Randy Randy is offline
This may be over kill but it sure makes removal easy. In my Subaru installation I use the large lowered exit area as a moveable cowl flap. I can remove it easily via the hinge pins.
I still need to be carefull with removal but it sure seems easier than it would have been with just a slot cut per the directions. Having a huge spinner gap doesn't hurt either
Randy C
RV7A Turbo Sube STI
Old 03-24-2009, 09:19 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
One idea I have toyed around with is making the nose gear leg slot longer by a few inches, toward the front, and then making up a removable filler piece that will bring the slot back to factory dimensions. This will mount with nutplates just like the filler behind the strut.
When it is time to remove the cowl, just remove the front filler, and the cowl will drop down far enough to clear the spinner----getting it by the prop should be simple then.
As I now have a removable scoop, I dropped the above idea, but it should work just dandy for anyone with the scoop still attached.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-24-2009, 11:54 AM
db1yg's Avatar
db1yg db1yg is offline
Hi Tom,
Not sure if my 9a solution is applicable to your 10, but here is what I did:
I used the Fairings Etc upper intersection fairing, cut off the front just about an inch forward of where the leg fairing inserts, and added about 2.5 inches to its length, and reglassed the front back on. This allowed me to extend my cowl slot just forward enough to be able to drop the cowl down and slide it down the gear leg (tape on leading edge of leg fairing to protect it from scratching) and forward to clear the 3 blade Catto prop. I have attached a pic to show how it looked after finish. Note that the white streak is a reflection off the white wing leading edge and not a scratch.
BTW, you might notice the round "port" in the transition area of the cowl just where the side of the scoop curves outboard -- this is a removable port directly under the oil quick drain--not necessary to remove the cowl for oil change.
Hope this helps.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 03-24-2009, 02:30 PM
bcondrey bcondrey is offline
While doing my transition training with Alex he pointed out that he had extended the gear leg slot forward and then made an aluminum cover plate for it. He's got a 2 blade but said that it makes removal a LOT easier - a few extra screws but then the lower cowl can drop down much further.
I copied this on my plane (also a 2 blade) and like it. Same solution would work for a 3 blade.
Bob
N442PM (flying)
Old 03-24-2009, 02:36 PM
vic syracuse vic syracuse is offline
Super Moderator
I extended the nose gear slot by about 2 inches, and used a piece of .063 to make a filler plate with nutplates. It fits underneath the nose gear fairing so it doesn't show at all, but makes removal a lot easier.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 03-24-2009, 05:30 PM
dmaib's Avatar
dmaib dmaib is offline
I extended the nose gear slot. I got info from someone on on of the forums that suggested extending the slot out to 4 and 1/2 inches from the scoop. I did this and then fabricated a cover that is fastened with the same Mil-Spec camlocs I used for the cowling. Sorry I don't have any good photo's, but I did find this one that shows the slot clearly. It works great with my MT propeller.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 03-24-2009, 08:06 PM
Deems Davis Deems Davis is offline
Default Cut the slot as far fwd, and make a cover
I cut a similar slot as far forward as possible, and fashioned an aluminum cover attached with nutplates.
I've got a 3bld aero comp prop, and I can drop the lower cowl enough to clear the lower 2 blades and then slde the cowl forward/down and off.
Her's a link to some pics:http://deemsrv10.com/album/Sec%2047%.../DSC04249.html
use the controls on the left to click forward to 'next image' there should be about 10 pics that show different views.
Deems Davis
RV10 N519PJ
http://deemsrv10.com/index.html
Old 03-25-2009, 10:28 PM
newtech's Avatar
newtech newtech is offline
I am still finishing up but here is a picture of my cowl. It is fairly easy to get on and off.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 03-26-2009, 04:14 AM
thanks to all for your thoughts and comments. Looks like some combination of extending the cut and putting in a reinforcement bracket will work.
Tom H
