Old 03-23-2009, 06:12 PM
Question Extra holes in baffles
On cylinder 4 and 3 baffle assemly there are sizeable precut holes. I am wondering what are those for? I am dual mags carb and top spark plugs ignition wires have their penetrations already. What's the best way to plug the oblong holes if they are not in use?
Old 03-23-2009, 06:17 PM
rvbuilder2002's Avatar
If you are talking about the hole in each side piece, they are for inserting a socket extension for removing the top spark plugs.
I think their is a detail in the DWG's somewhere suggesting how to make removable plugs for the holes.
Scott McDaniels
Hubbard, Oregon
Old 03-23-2009, 06:29 PM
Alright. But why only 4 and 3? Looks like 1 and 2 need their respective baffles notched because an extension doesn't fit there.
I will look through drawings for removable plugs instructions.
Old 03-23-2009, 06:35 PM
On #1 and #2, the geometry allows the extension to pass over the top of the baffles, instead of needing to go through the baffles like on #3 and #4.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-23-2009, 06:36 PM
Once you have trimmed the height of the side baffles down to fit the cowl contour, an extension will be just slightly above the baffle sides on Cyl 1 & 2.
Scott McDaniels
Hubbard, Oregon
Old 03-23-2009, 06:38 PM
Now understood. Thank you gentlemen. That's good to have the virtual help in the shop
