03-23-2009, 02:28 PM
25 hour test requirement instead of the 40 hours
I?m getting close to the certification of my RV8A.
My DAR has asked if I can correlate the engine and propeller combination (vans parts) with any kind of production aircraft.
This would allow him by similarities to only require a 25 hour test requirement instead of the 40 hours.
Have any of you run across this before?
Do you have a solution that I can offer to the DAR to only require the 25 hour flight test?
Below are the engine and propeller combination that I purchased from Vans.
Experimental O-360 180HP
LYC XO-360-A1A
Compact hub Constant-speed prop for (I)O-360 (180/200hp) 74"
PROP C2YR-1BFP/F7497
thanks
03-23-2009, 02:38 PM
You can stop right at the engine. The LYC XO-360-A1A is an experimental engine, thus you get 40 hours.
The regs state that to get 25 hours you must have a certified engine - prop combination. Meaning that if you could pull an engine and prop right from a certified aircraft and stick in your homebuilt, you get 25 hours. Since you opted for the experimental Lycoming, even though it is identical to a certified O-360-A1A, you get 40 hours, regardless of what prop you stick on it.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
03-23-2009, 02:39 PM
"LYC XO-" does it for me. You're not going to find one of those on anything certified.
Scott Card
CMW E-Lift
03-23-2009, 02:59 PM
I experienced this same issue. Van's directed me to Hartzell Propeller Inc. for pertinent data. The link includes a list of propellers for use in RV's. http://www.hartzellprop.com/kitplane/index_kitplane.htm
I called Hartzell and was told specific approved engine/prop combo information can be accessed at the FAA. I never could figure out how to access that information.
In any event, my DAR approved the 25 hour test period when he understood the OEM YIO-360-MIB I purchased through Van's and shipped directly from Lycoming is essentially identical to a "certified" engine. Apparently other builders have used DAR's that do not see things the same way. Lucky me.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
03-23-2009, 03:46 PM
If the DAR elects to issue a 25 hour flight test period even if the engine/prop combination otherwise requires a 40 hour flight test, where does that leave the builder? Does he have to follow the regs which require 40 hours? Or can he sign it into Phase 2 after 25 hours based on his operating limitations?
I'm using a Subaru engine and a carbon Sensenich prop, but my DAR issued me a 25 hour flight test period.
Thoughts?
Paul
03-23-2009, 04:16 PM
Thoughts?
Paul
My thoughts: Wow.
Scott Card
CMW E-Lift
03-23-2009, 04:26 PM
been here awhile
Amazing.................
In regard to your original question, if your op lims say twenty-five hours, that is all you are legally obligated to fly in Phase one........I guess......it's difficult to understand the rational of the DAR...............
03-23-2009, 05:45 PM
Paul
My first thought is that your DAR may not be one for long. A DAR may require MORE hours but he cannot approve LESS!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
03-23-2009, 06:57 PM
Since you know that you should use 40 hours why not call the DAR and have the time corrected?
03-23-2009, 07:05 PM
fugio ergo sum
What is the problem?
Nothing about having been issued a 25 hour test period means that you have to take a passenger up at 25.1 hours. Fly your test program and get confident with the airplane. That should take longer than 40 hours anyway.
I wonder how many hours Kevin Horton is into his test program now? Probably a lot more than 25 hours and it is with traditional parts.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
