Old 03-23-2009, 01:03 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default To Weld or Not?
I am getting ready to fab the aileron push rods and was interested if anyone had tig welded the aluminum tube? I have found lots of info on welding the 4130 tubes, just not any on the aluminum. If they are weldable (I have not checked). I have a TIG machine and have no problem doing it if it is acceptable, otherwise I will just rivet them.
Any info?
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 03-23-2009, 01:26 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Never mind....
edit: I didn't read close enough...........because it's the shorter steel rods that I had welded. It's very easy to rivet the larger diameter aluminum rods.
L.Adamson --- RV6A
Old 03-23-2009, 01:49 PM
DanH's Avatar
DanH DanH is offline
Weldable depends on alloy. Check the markings on the tube. If unsure, don't weld.
Common alloys, tig or gas:
1100, 3003, 5052, 6061, yes.
2024, no
Keep in mind you lose the existing heat treat. For example, 6061-T6 becomes 6061-0.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-23-2009, 02:03 PM
mburch's Avatar
mburch mburch is offline
Dan,
You are right I'm sure, but just wanted to mention that (unless my memory fails me) the plans do explicitly state that welding is an acceptable option for the steel pushrods between the ailerons and the aileron bellcranks. I had mine welded just because I knew a guy who could do it.
Agree that the aluminum pushrods should all be riveted per plans.
cheers,
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 03-23-2009, 02:18 PM
JonJay's Avatar
JonJay JonJay is offline
Those are very easily riveted. I would not deviate from the plans on the aluminum push tubes.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-23-2009, 02:48 PM
L.Adamson's Avatar
Originally Posted by mburch View Post
Dan,
Yes, somehow the aluminum part skipped my brain. It was the shorter steel rods that I had welded. I have ammended my reply.
cheers,
mcb
