Should there be any? They show terminal 3 of the switch connected directly to the battery. I was wondering about putting a 7 Amp fuse in there... what's common practice?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
It really depends on the size of the wire that you are going to use. The fuse is only there to protect the wire not the device. Mind you if you are using a really large guage wire and the device only draws a very little current it would be prudent to use a smaller fuse.
