Old 03-19-2009, 04:31 PM
prkaye prkaye is offline
Default proximity of wires to priming tube
Is there a specific minimum acceptable distance from wires (e.g. the 8AWG wire penetrating the firewall to the main bus) to the copper priming tubing? What would you generally consider to be an acceptable minimum spacing?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
