03-19-2009, 08:22 AM
Airworthiness Certificate
This may be a dumb question, but I am curious if the pink A/W certificate the DAR issued is the permanent certificate? Or, will a permanent certificate be issued from OKC? (like the registration certificate)
I am gathering information for future Bahama's flights and that got me thinking about this issue.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
03-19-2009, 08:24 AM
That's the final one. OKC does not issue a seperate C of A.
03-19-2009, 08:27 AM
You are set for the A/W certificate. It does not expire.
It is the white registration certificate you will need to reenter the U.S.
Randy Hooper
03-19-2009, 11:55 AM
Thanks Randy and Scottg
David Maib
RV-10 N380DM
VAF Paid 1/21/2020
Jackson Browne
03-19-2009, 01:37 PM
Maybe, Maybe not!
An 8130-7, Special Airworthiness Certificate, may expire. Look at the expiry block. Most will say "Unlimited" but not necessarily. There are special cases when we will issue Phase I only and give a one year expiry on the Airworthiness Certificate.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
03-21-2009, 07:10 AM
Radio license
Don't forget that you will need a radio license. The US grants an exception to the rule, so nobody gets this for flying in the US. But when I visited the Bahamas (I also live in Florida like you) they DEFINITELY wanted to see my certificates including the radio license when I landed in Marsh Harbor.
Enjoy the Bahamas.
Rich Wilson
RV-8 N707RW
03-21-2009, 08:10 AM
Then what?
Mel, you and I have discussed this before - but I don't recall this answer: So if your expiry block does have a date, how do you renew it when it expires, and can you then request the 'unlimited' stamp?
Clayton Henderson
Beaumont, TX
RV-7 N454CH (Flying)
03-21-2009, 08:17 AM
It depends on why the expiration date is there. The operating limitations should explain. If they are issued for phase I only, you will need a new inspection. This would be the most common reason.
Another possible reason (not for RVs) is the grandfathered E-LSAs that were being used for training expire 1/31/2010. In this case they may be amended without an inspection because it is simply a change is operating limitations.
