Old 03-18-2009, 11:45 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default help - how do I crimp 8AWG terminals?
Anybody have a good tool to do this? The "Terminal Tool" doesn't go down that small, and my Stein ratcheting crimper doesn't go up that big.
Thanks for any info,
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 03-18-2009, 11:53 AM
chaskuss chaskuss is offline
Dave,
I used a commercial electrician's crimping tool. This tool is used to crimp the Burndy terminals they use. The tool looks like a pair of bolt cutters, with adjustable dies on it. The set I borrowed went down to #8. Do you have any electrician or avionics tech friends? If so, perhaps you could borrow a pair. Maybe someone in your EAA Chapter has one. That's how I borrowed the one I use.
I don't know who makes the low budget tool for doing that job.
Charlie Kuss
PS Here are a couple of links to show what these tools look like. I used a larger one made by Greenlee (see 3rd link)
http://www.tessco.com/products/displ...id=google_base
http://www.graybar.com/webapp/wcs/st...ed+Compression
http://www.greenlee.com/products/CRI...oduct_id=19104
Last edited by chaskuss : 02-27-2013 at 01:00 PM. Reason: updated old dead web link
Old 03-18-2009, 11:58 AM
plehrke's Avatar
plehrke plehrke is online now
Ask your local A&P. I found most I know have one. Your local repair shop my let you bring your wire in and crimp it on the spot for no charge (as long as you do the squeezing)
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 03-18-2009, 12:06 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Dave,
I used the $8.85 crimper from www.weldingsupply.com (Item # 04040). Worked great for AWG 2 - 8 wires, and you can't beat the price. The crimps are very strong.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 03-18-2009, 01:04 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Originally Posted by bullojm1 View Post
Dave,
Dave-
Search the forum archives for this tool from weldingsupply. A number of us have recommended it in the past. Works great!
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 03-18-2009, 02:33 PM
allbee allbee is offline
believe it, I use a holder to drill a hole in a tube. They are pretty cheap, I got mine from cleaveland tool. What you do, and I've used this on all wire down to 2agw. Put the wire in the end, put it in the holder and take a punch, wide one and hammer it, worked great for me.
Old 03-18-2009, 04:12 PM
Norman CYYJ Norman CYYJ is offline
If you have some AL bar stock you can drill a hole the proper diameter in it for the connector. Cut through the hole with a hacksaw cutting it in half. Place each half then over the connector with the wire installed and place the whole unit into a vise and squeeze it shut. That should work fine if you can't find the proper tool to borrow.
Old 03-18-2009, 05:17 PM
7DeltaLima 7DeltaLima is offline
Dave,
I'm down the road from you in Muscatine. I have one of these....
"I used the $8.85 crimper from www.weldingsupply.com (Item # 04040). Worked great for AWG 2 - 8 wires, and you can't beat the price. The crimps are very strong. "
You're welcome to use it if you want to drive down.
btw... there is a builders assist shop out at KCID. Can't remember the name of the guys but bet they'd have something as well.
Doug....
Doug
RV-7A N277DL flying 4-15-2004
RV10 N277CK flying 5-28-2010
www.oncloud7.com
Last edited by 7DeltaLima : 03-18-2009 at 05:20 PM. Reason: added the builders assist note
Old 03-18-2009, 06:44 PM
Thanks guys - how does that funny looking $8.85 tool work? Do you squeeze it in a vice?
Marion IA
Old 03-18-2009, 09:08 PM
G-force's Avatar
G-force G-force is offline
Wasn't somebody (Avery, Cleavlend, etc.) making 8 ga crimping lugs for our pnumatic squeezers? Perhaps I'm remembering a custom set somebody made and posted about once.
Mike Sumner
Castaic, Ca
