Old 03-17-2009, 03:54 PM
burgundyja's Avatar
burgundyja burgundyja is offline
Default trim tab wire
do you think this is ok routing for the trim tab wire? it is a 8a.
http://img21.imageshack.us/gal.php?g=dsc02640rbr.jpg
Mike Johnson
8A N484M
Old 03-17-2009, 05:41 PM
Danny7 Danny7 is offline
Default first pic doesn't look good
In your first pic the wires are running close to or right on top of a stiffener, or the edge of a piece of AL. I'd think after some hours of flight that would chafe right through the wire. you should get a way to pad the wires or route them better, in my inexperienced opinion.
nothing special here...
Old 03-18-2009, 07:59 PM
ignacio ignacio is offline
i would not use the tie wraps to secure the wire to the rib like that. buy cushioned clamps and bolt them on, more secure and will last longer, tie wraps crack with time.
Old 03-18-2009, 08:51 PM
Aviator168 Aviator168 is offline
Shouldn't let wires touch any shape edges. Wrap the wires with a piece of cushion first then tie them up. You can get heat resistant cushion pad from Target.
