Originally Posted by tommylewis
Frank - you posted "One thing I did to get it sliding really smoth was to put a 1/16" delrin pad on the wheel mount on each side (between the track and wheel mount)this holds the wheel dead center"
What is a 1/16" delrin pad??
Tom Lewis
RV7a canopy
Delrin
From Wikipedia, the free encyclopedia.
Delrin is the brand name for an acetal resin engineering plastic invented and sold by DuPont. Often marketed and used as a metal substitute, Delrin is a lightweight, low-friction, and wear-resistant plastic capable of operating in temperatures in excess of 90 degrees celsius (approx 200 degrees Fahrenheit). The Food and Drug Administration has approved Delrin for use in the food industry. Delrin was used by Mattel from 1968 to 1972 to produce the low-friction wheel bearings found on redline Hot Wheels.
It is also used extensively in paintball markers, where it is used to make bolts, rams and many other parts. Its low cost, adequate strength, light weight and self lubricating properties make it ideal for markers. Its competition in this area, Nylatron, while slightly lighter is more prone to swelling. A swelled part can make the mechanism impossible to operate and sometimes even damages the marker.
Other names for this compound include: polyoxymethylene (POM), acetal resin, polytrioxane and polyformaldehyde.
