Originally Posted by Mel
Normally sized firesleeve will slide over the fittings.
Mel,
So, if the hose has an OD of 0.5" an
Aeroquip AE102-8 1/2" has enough stretch to go over the hex 'points' of a fitting that are 3/4" across? Or, should I go with something with larger ID...3/4" ??
Steve, Thanks for the heads-up on that. Could have been an expensive "gotcha".
