Old 03-15-2009, 01:47 PM
prkaye prkaye is offline
Default radio depth
The SL-30 is 11 inches deep, according to Aircraft Spruce. The subpanel sits only 9 inches back from the panel. How on earth are you supposed to put something like an SL-30 in an RV? Is this depth typical of most NAV and NAV/COM units??
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 03-15-2009, 01:53 PM
SteinAir SteinAir is offline
Phil,
Either slam it in there with a really big hammer, or do what everyone else does - simply cut a hole! This might be the first hole you cut in the sub-panel but it likely won't be the last!
Stein
Old 03-15-2009, 01:59 PM
boom3's Avatar
boom3 boom3 is offline
Here is a picture to give you an idea. Both my SL-30(bottom) and GNS-430(top) had to penetrate the subpanel.
Get the trays ahead of time if you can.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 03-15-2009, 02:00 PM
Thanks! i guess cutting a hole is the obvous answer! Actually that makes sense... if I cut the holes just right, the subpanel will provide additional support for the back end of the radios.
Phil
RV9A (SB)
Ottawa, Canada
Old 03-15-2009, 03:20 PM
pierre smith's Avatar
Default You'll need to rivet aluminum angles there..
....Phil. Angle under the lower tray for support, not just the sharp edge of the bulkhead.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-15-2009, 05:07 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Originally Posted by SteinAir View Post
Phil,
Stein
And the gap is smaller on a -6
