Old 03-15-2009, 05:41 AM
dan carley dan carley is offline
Default oil pressure light
i'd like to install a low oil pressure light in my rv. can one be made or is there a kit you can buy? where would you get one?
thanks
dan carley
RV-4
N14FT
Old 03-15-2009, 06:28 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
My oil pressure light is a amber colored 12volt LED; with built in resistor from Radio Shack. It's activated by a oil pressure switch that's available from Vans. The pressure switch also activates the Hobbs meter.
http://www.vansaircraft.com/cgi-bin/...ct=isspro-hour
L.Adamson --- RV6A
Old 03-15-2009, 06:30 AM
pierre smith's Avatar
Default It's easy, Dan...
.....to simply tee into the oil pressure sending line and install a cheap pressure switch that's normally closed and wire the light to it.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-15-2009, 07:30 AM
noelf noelf is offline
Default The Aeroelectric Connection...
...web site has a drawing and parts list for just that.
Old 03-15-2009, 07:56 AM
Sam Buchanan's Avatar
been here awhile
thanks
dan carley
RV-4
N14FT
Here is the whole kit for $16.00:
http://www.speedwaymotors.com/Warnin...-Kits,897.html
I have this setup on my RV-6. Whenever I get around to it I might change out the switch for a "15 lb" switch that will turn on the light earlier:
http://store.summitracing.com/egnsea...17507&D=317507
The main reason I installed the warning light was so it would serve as a "Turn Off the Master You Idiot-Light".
Sam Buchanan
RV-6
Fokker D.VII replica
Old 03-15-2009, 08:07 AM
captainron's Avatar
captainron captainron is offline
Just make sure you support all this stuff to protect from vibration. To just keep adding nipples, tees, sending units, etc. from the oil pressure port on the engine is a sure way to insure that your light WILL come on!
Guess I should modify that: If the sending unit breaks away from its grounding source, you'll still lose all your oil, but you won't have to stare at the light!
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 03-15-2009, 08:30 AM
CNEJR CNEJR is offline
I used a "Low Oil Sensor" which fits into the sump, it comes on if the engine falls to 4 qts. of oil. I thought an early indication of loss of oil would be more important than waiting for a light which showed imediate low oil pressure. Of course I do have an oil pressure indicator on my EIS/EFIS. Something to think about.
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
Old 03-15-2009, 12:21 PM
been here awhile
It should go without saying that sensors and switches should not be mounted on the engine. My oil pressure switch is teed off the pressure line at the remote sensor on the firewall. The firewall-mounted remote sensor manifolds that many builders are now using make it very simple to add the pressure switch.
Sam Buchanan
RV-6
Old 03-15-2009, 07:21 PM
Steve Barnes Steve Barnes is offline
Default Bright Light
I installed a bright red light to let me know that I left my master on. All it is, is an oil pressure sensor. I never have left my master on, thanks to the bright light.
Steve Barnes the Builders Coach
