Oops!! Move on or Start Over
I am in the process of finishing up my tanks and have put off the tank attach angles for last. Well at first I did not see that I was suppose to set the angle 2 inches back from the leading edge. Called Vans and was told to make new angle and keep the rib. So today I am drilling the new angle to the already drilled rib. Now all my hole are about a 1/8 inch aft from my first location. My problem is that I can not put the flop tube bulkhead fitting on the 1 1/8 mark per the plans. Does this matter? I can still get it there 3/16 aft of centerline. I don't know if this will cause problems when I get to the fuse. Thanks
Michael Brown VAF #1458
Elkton, MD
Building RV-7
N227MB (Reserved)
Empennage Done
Wings Under Construction!
