Old 03-14-2009, 10:00 AM
hudgin hudgin is offline
Default Cowl vents
There is discussion here about which way to install the louvers in the cowl. Smooth side outside for less drag, works just as good or bumps outside causes venture effect works better. What are the experiances?
And I just saw in one of the forums to install them on the side instead of on the bottom for better cooling?
Doug
