03-13-2009, 05:06 PM
Right Elevator lite
In balancing my right elevator I seemed to have trimmed to much off of the weight thus making it not heavy enough to be in proper balance to the HS..I ran across a website somewhere that had a fix for this, but of course now I can't find it..can anyone assist.?
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
03-13-2009, 05:29 PM
One way I have heard of is to drill a hole in the elevator counterbalance arm or fairing and mix some lead shot with epoxy and pour it in while arm pointed down and let epoxy/shot mixture harden up.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
03-13-2009, 05:54 PM
Question for Others?
My LH elevator with electric trim motor seems a tad light and I haven't touched the weight yet. The RH elevator is heavy at the moment. I was planning to balance them as a pair since they are connected at the horn. Does that make sense?
Jim Sharkey
03-13-2009, 06:44 PM
Ryan...Jim
I'm pasing on the advice I got when at your stage........DONT BALANCE ANYTHING UNTIL AFTER YOUR AIRPLANE LOOKS LIKE AN AIRPLANE AND IS READY TO FLY!.....was that subtle enough
Robb....7A...2nd wing almost done...fuse on the way
03-13-2009, 09:28 PM
Please feel free to file this as useless information but a very well known test pilot I know says that some very knowledgable people believe that having a slight difference in balance with controls surfaces is a good thing. This way flutter shouldn't happen at the same speed on both control surfaces.
ymmv
Tom
03-14-2009, 04:44 AM
Paint changes balance.
Bear in mind, painting the assembly will alter the balance by few ounces.
This from personal experience. The weight of the paint on the elevator will be higher than the weight applied to the counterbalance arm.
As for adjusting: If you drilled holes, melt some lead with a propane torch and fill some of the holes. If you trimmed the weight, new ones are not very expensive.
YMMV
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
03-14-2009, 06:23 AM
Elevator balancing
Don't balance your elevators until your aircraft is painted, assembled, and ready for flight. Then level the fuselage in both axis, (level flight attitude).
If you do it before this, everything will change when painted and assembled.
Danny King
Beautiful Doll 80434 TT 1675 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2020
03-14-2009, 06:29 AM
second that
One lesson I learned was to not worry about the elevator balance until all is ready for final rigging. OK to balance the elevators as an assembly per Vans. No matter what you do, it will all change when you are ready for the final rigging, so I think it is best left until last. Lesson learned.
Good luck,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
03-14-2009, 06:33 AM
Hmm. This would lower the flutter speed for one of the elevators. Given that even single elevator flutter would probably lead to HS failure, and loss of control, I'd prefer the keep the flutter speed as high as possible.
Ideally, each elevator would be balanced individually. This way any small flexibility in the structure that connects the two elevators together does not enter in the equation, and the airspeed at which flutter starts will be the highest. But, many RVs have been built where the elevators were balanced as a unit, after bolting them together, and RVs are not falling from the sky due to flutter.
I balanced my elevators individually, but I would have no concerns about flying an RV that had the elevators balanced as a unit.
03-14-2009, 07:28 AM
ok I will wait. Just wanted to finish up the fiberglass and rage filling, guess that will wait too.
Ryan Allen, CFII
E-170/175
