I found this really neat labeling system called Rhino Pro 5000. It is a battery powered hand held Dymo printer that prints on heat shrink tubing. The heat shrink is in cartridges and snap into the rear making it super easy to change sizes. A couple of pictures and a link is posted below. You can see several different sizes stored in the case. I know there are other ways to accomplish the labeling but I had never seen this printer. It can be purchased for under $100, maybe less on ebay. The pictures are not the greatest but you can see the result pretty good in the second picture.
You can read more about it here.
http://www.labelcity.com/rhinopro/rhinopro5000.shtml
The heat shrink is available in multiple sizes and in white or yellow.
