Old 03-12-2009, 04:04 PM
prkaye prkaye is offline
Default Accelerator pump??
I'm getting ready to install Vans FAB. The instructions (under "O-320 only") speak of an "Accelerator pump", I think which is supposed to be part of the carb. What/where exactly is this pump?? I have a Precision Carb (Model MA-4SPA).
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 03-12-2009, 04:09 PM
gasman gasman is offline
On the left rear.......... It has a little rubber boot around the base of it....iirc
Old 03-12-2009, 04:13 PM
Steve Sampson Steve Sampson is offline
If you look at the last photo here, its the bit on the right hand side. you can see the plunger at the top. At the bottom is the bit that causes you to modify the air filter if I remember correctly.
When you move the throttle forward this injects extra fuel into the carb..
Hope that helps.
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
