  #11
Old 03-15-2009, 06:51 PM
24Golf's Avatar
24Golf 24Golf is offline
Default Thanks..
Thanks for the input... one other thing that I see on the ECI quotes is the angled oil filter adapter - How does the factory Lycoming oil filter mount??
Paul & Beth Duff
N2724G - RV9A - 1000+ Hours
Vans # 91642
FLYING 10.15.2010
BLOG: http://2flyamerica.com/
Old 03-16-2009, 02:00 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
The Lycoming 0360 A1A from Van's was straight out the back.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 03-16-2009, 03:11 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Mattituck shows...
....both styles here --
http://www.mattituck.com/oil%20filte...pter%20add.pdf
Note that a O-360-A1A may come with only an oil pressure screen, but apparently Vans gets them with the filter as Roberta says.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-17-2009, 07:30 PM
Bevan Bevan is offline
Default cam lube
Originally Posted by Guy Prevost View Post
I've been extrordinarily happy with my ECI built by Mattituck. I feel they offer some real advantages; crank thrust bearing, nickel carbide cylinders, O-rings at the case bolts, oil jet on the cam, etc.
Guy
On an ECI engine, how is the cam lubed differently from lycoming? And if the engine won't be run all winter long, how is the cam to be kept lubed up?
Bevan
Old 03-17-2009, 07:50 PM
az_gila's Avatar
Exclamation Rob Attaway's picture...
Bevan
...shows the extra nozzles that squirt oil on the cam -
They are not on most of our true Lycoming O-360s...
Gil Alexander
Old 03-17-2009, 08:46 PM
Default cam lube
Thanks for the excellent picture. I see the cam oil nozzles. What's the procedure prior to months of just sitting? I'm thinking of adding a preoiler, and running up the oil pressure periodically. Will this be enough pressure to squirt the cold oil onto the cam to recoat?
Bevan
Old 03-18-2009, 08:14 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
Bevan
Mattituck told me that some people do just that. My solution is to fly every weekend. Of course, I live in the desert.
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 04-14-2009, 07:41 AM
afii58 afii58 is offline
just curious, what about this AD I just found on line about eci cylinders? Said they had to be inspected every 50 hours, no if's and's or but's. I assume all eci kit engines have them, plus I guess they can be put in other brand of engines?
We are in the process of picking an engine for our rv8, either the lycoming from van's or an eci titan kit. Any comments about the AD
Old 04-14-2009, 08:18 AM
It was just a batch of ECI cylinders, not all of them. My ECI cylinders for instance are not affected.
Guy Prevost
Albuquerque, NM
Old 04-14-2009, 08:22 AM
rvator51's Avatar
rvator51 rvator51 is offline
Bevan
Any idea where you would get a preoiler from?
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
