Old 03-11-2009, 04:48 PM
prkaye prkaye is offline
Default lock washers
The washers taht came with my engine/carb to go under the 4 nuts holding the carb onto the engine included 4 AN936 internal tooth lockwashers (AN5 size). I've had to remove and reattach the carb, so I feel I should use fresh lockwashers. Unfortunately Vans only supplies the AN936 washers in the AN4 size. Would an acceptable substitute be the AN935 style lock washers (AN935C516)? Also, should these lockwashers go between the nut and the AN960 washer, or between the AN960 washer and the surface of the carb?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 03-11-2009, 10:19 PM
aerhed aerhed is offline
Nut, lockwasher, plain washer, fastener. I've always liked the split washers, sometimes tooth washers crack. Not often, once in awhile. Split washers are standard on some spam can carburetors. Make sure you have enough stud length.
Old 03-12-2009, 04:52 AM
plehrke's Avatar
plehrke plehrke is offline
Default Drilled nuts
For all places I use a lock washer I replace everytime I remove the nut. get your self some extras of the style you like. I use the starwashers for electrical (better electrical contact) and the splits of other applications.
For my fuel injection servo installation I decided to use drilled nuts and lock wire them together. I guess I trust lock wire more then a lockwasher. The lock wire should not effect the flow into my fuel injection servo as it is next to the rubber seal of the K&N filter. should be in the stagnet air region.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 03-12-2009, 06:52 AM
WenEng WenEng is offline
Default Order 100 of these from skyranch for $4.00
Lycoming has used these for over 50 years. They work fine. Just use new ones any time you take them off. Like an earlier poster said, its nut, lockwasher, flat washer.
MS35333-41 LOCK WASHER (AN936-A516)
http://www.sacskyranch.com/acatalog/...eries_100.html
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 03-12-2009, 07:51 AM
Default cool!
wow, great source... I'll order those up!!
Phil
RV9A (SB)
Ottawa, Canada
Old 03-12-2009, 08:12 AM
vlittle's Avatar
vlittle vlittle is offline
Make sure that you order 100... you'll use them up quickly as you work on the engine. Also, order 100 copper spark plug washers... it's nice to keep a supply. Don't tell your friends you have them.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 03-12-2009, 10:30 AM
Kevin Horton's Avatar
Phil,
I've got dozens of internal lock washers in AN3, 4 and 5 sizes. I can give you the ones you need, if you want. You can buy me a beer someday, and we'll call it even
Lock washers are definitely something you only use once, so you should get a bunch of all the sizes on your aircraft. You will need them eventually.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 03-12-2009, 12:09 PM
Thansk Kevin! I think I'll go ahead and buy 100 of each size from that supplier mentioned above. As you said, would be good to have a tonne on hand. Thanks again!
Instead, I'll buy you a beer in exchange for some flight testing advice, hopefully next summer (2010)!
Phil
Phil
RV9A (SB)
Ottawa, Canada
Old 03-12-2009, 12:53 PM
Actually,. ACS has them, for about the same price 0.04 each.
Phil
RV9A (SB)
Ottawa, Canada
