Cool
I run into this at work. When flying and deciding what is the best altitude you need one key piece of data that is not always available, actual winds at other altitudes. The flight plane was done with forcast and best altitude based on weight, trip distance and weather (winds).
We can ask ATC for other aircraft PIREPS for winds, but many times none is available. We know the winds at our altitude but unless you have actual winds, you don't know if it's worth climbing or descending. George
