03-11-2009, 12:31 PM
Paperwork after a prop change?
If I change my FP Catto Prop with a different FP prop, Catto or some other brand such as the new Sensenech prop, what do I have to do with my log books? New W&B? Contact the FAA and change my paperwork with them?
Also, do I have to put it back into Phase I for any length of time?
Is there anything else I should be aware of?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
03-11-2009, 02:33 PM
Super Moderator
Yes, Bill, a propeller change is considered a major modification unless it is just a replacement with the exact type (pitch change would be OK), and will require you to notify the local FSDO as per your limitations. Typically, you will have to go back into phase I for 5 hours.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
03-11-2009, 03:21 PM
That's what I thought. Thanks Vic!
Bill R.
SC86 - Easley, SC
03-11-2009, 03:23 PM
Will it require a new weight and balance?
Webb Willmott
Jackson, MS
N32WW
03-11-2009, 10:08 PM
Shouldn't require a complete new weighing. You should be able to just calculate the changes and enter into the logbook (i.e., empty CG is now at xx inches rather than yy inches). I have all this stuff on an excel spreadsheet, so when I moved my battery, I just took 15 pounds off where it used to be and added 15 pounds where it is now (multiplied of course by the arm).
I also figure that once I am done (ha ha) with the little modifications like moving the battery and am painted, I will probably reweigh just for my peace of mind.
cheers,
greg
Greg Arehart
N 7965A
