Old 03-11-2009, 12:13 PM
flickroll's Avatar
flickroll flickroll is offline
Default Grove Gear Brackets
The brackets supplied with the Grove gear are black, which appears to be some sort of coating. However, in talking to Grove, they said the black stuff is just a byproduct of heat treating. My question is, to those who have installed a Grove gear, what sort of coating did you apply to the fittings? Or did you leave them as-is and will rely on occasional oiling (LPS-2, etc.) for corrosion protection? Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 03-11-2009, 01:48 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Builder Option
Originally Posted by flickroll View Post
.....to those who have installed a Grove gear, what sort of coating did you apply to the fittings?.....for corrosion protection? Thanks
Jim,
Choices, choices. We all have to make them. Wherever I wanted the maximum in corrosion protection, I applied a popular high quality epoxy primer widely used in aerospace that is highly resistant to dirt, fuel, chemical and hydraulic fluid damage. The polished Grove gear was masked off and Akzo primer was applied, protecting the covered and hidden surfaces of the landing gear assembly such as underneath the wheel pants and intersection fairings.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 03-11-2009, 03:22 PM
mlwynn mlwynn is offline
Default Priming the Grove backing plates
I did exactly the same thing as Rick. In fact, that picture could be my plane. --Nice work, Rick.
Michael Wynn
RV 8 FWF
San Ramon, CA
Old 03-11-2009, 09:36 PM
flickroll's Avatar
Nice looking installation Rick. I'll do something similar. Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
