Old 02-24-2009, 06:55 PM
Scream's Avatar
Scream Scream is offline
Default Small vs Large N Numbers
What size tail numbers does everyone use/plan to use? A summary of CFR 14 Sec 45.29 says that if an experimental that has a cruise airspeed above 180 the large N numbers are required. Ok... I have seen pictures of -8s with small numbers and several with large numbers.
How do you justify it with the FAA? Do you just use the 75% cruise numbers that Van's provides? (160HP=197mph/171knots, 180HP=204mph/175 knots, 200HP=212 mph/184 knots)
Using that logic, if you install a 200 HP engine you need 12 inch letters.
I am curious only as an academic exercise, but prefer the small N numbers.
http://ecfr.gpoaccess.gov/cgi/t/text....363.6&idno=14
Tail Feathers complete; down for a 2 year hiatus...
Old 02-24-2009, 07:44 PM
John Clark's Avatar
John Clark John Clark is offline
Default Easy...
The regulation states 180 knots calibrated airspeed, meaning indicated.(IAS) Van's numbers are true airspeed. 180 knots indicated at 8000 feet (on a warm day) is around 212 knots true (TAS). That is my story and I'm sticking to it.
John Clark
RV8 N18U "Sunshine"
KSBA
Old 02-24-2009, 09:05 PM
Scream's Avatar
Default "True" Airspeed
Sounds like a good enough reason for me...
