Old 03-09-2009, 05:43 PM
sahrens's Avatar
sahrens sahrens is offline
Default QBuild Wing Rack?
I have ordered the QB wings from Vans. I know they are completed enough that I do not need a jig, but I will need something to hold them while I complete them. Does anyone have any suggestions, plans or ideas for some kind of storage / work platform / whatever you would like to call it for the QB wings.
Thank you in advance for your suggestions and ideas.
Scott
Old 03-09-2009, 05:54 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default 2 x 4's and carpet strips
Scott
For the outboard end, a big W with parallel uprights and then half-loops of carpet strip work well. Keep them on the ribs. When you need access, you can easily reposition them. For the inboard end, make an upside down U with parallel legs and a flat cross member on which you can secure the spar ends. There are many more elegant solutions around. This was my quick way of dealing with the lack of a template for the airfoil shape. It served me well. It was reasonably easy to fit the flaps, aileron brackets and wingtips while in the brackets.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 03-09-2009, 09:12 PM
Dave Watson Dave Watson is offline
This worked great for me.
http://smittysrv.com/more_stuff.asp?ID=380
Dave Watson
RV-9
Locust Grove, GA (Mallards Landing)
Old 03-09-2009, 09:54 PM
BuckWynd's Avatar
BuckWynd BuckWynd is offline
Scott,
I made a wing stand from a set of plans published by EAA some years back. Here's what it looks like:
Sorry I don't have a photo of it without the wings on it, but you can probably figure out the details. I got the carpet strips for free at a carpet store.
Buck Wyndham
Northern Illinois
RV-8 N18XL
Old 03-09-2009, 11:13 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Here's what I did:
http://kochman.net/N819K/?p=45
Outboard leading edge goes on the carpet, and the front of the spar goes on the 2x4 at the other end. If you want to rivet the bottom skins while in the cradle, make sure all the carpet is forward of the spar, so there's no interference.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 03-09-2009, 11:56 PM
BuckWynd's Avatar
Here's the EAA diagram I was talking about. It has some dimensions on it, but I'm not sure they're correct for RV wings:
Wing rack plans
Buck Wyndham
Northern Illinois
RV-8 N18XL
Old 03-10-2009, 08:28 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default EAA model suggestions
I did the EAA type that is shown in the picture in the 3rd reply. As suggested, I used some carpet strips for slings. The only problem was that as the carpet frayed it made a mess. My solution was putting duct tape on the carpet edges. That was OK for a while but as the duct tape aged it got to be messy and left glue residue on the wing skins.
I later saw a suggestion to try and find some discarded firehose to use for the slings. If I build another one, I will definitely be looking for some old fire hose.
My other suggestion is that shorter may be better. When I was getting ready to install my Duckworks landing lights, I realized that the slings would go right where the lights get installed. So I had to delay putting in the lights (and they are still not installed).
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 03-10-2009, 01:19 PM
sahrens's Avatar
Default Thanks
Thanks to all of you. This is exactly what I needed
