Originally Posted by dwilson
I tried drilling the 9A landing gear weldments in place through the side skin of the fuselage tonight. In 6 holes I severly dulled 2 bits. What am I missing here? Do I need really hard bits such as cobalt bits or am I doing something stupid?
Duane Wilson :
Could be any number of things, all of them related to technique. Without knowing what you are doing
specifically, in general I would suggest the following. Always pilot drill holes first with either a #30 or a #40. Since in this case it is a rather thickish steel weldment, I would personally feel a bit more comfortable using a #30....less chance of a #40 snapping off in the hole. Step up the hole to final size in increments. Use a reamer for the final pass. Use a relatively low RPM....with a moderate feed pressure, using boelube or any oil for that matter as a lubricant on the tip of the drill bit, even candle wax will work,....do not force the hole with heavy pressure and/or the drill motor running wide open. Go slow and easy. Use SHARP drill bits. High speed drill bits will work just fine but do not last as long as cobalt drill bits. Don't be afraid to throw dull drill bits away..... unless you have a bit sharpener. Bottom line...sharp drill bits, pilot drill the hole first, drill hole in stages using a low rpm. For instance to drill a 1/4" bolt hole , I would pilot it first, bring it up to 5/32, then to 15/64, then final ream with a .2495 or .2500 reamer.
Rick Galati RV-6A "Darla"
