Phil,
I looked at LSE's website and in the FAQ section it says this:
"...all Plasma II Plus and Plasma III CDI systems can be operated with a standard aircraft key switch. A "P"-Lead (wired to the output connector) is provided and should be connected to the key switch in the same way as the magneto "P"-Lead. There is no current drain on your battery when power is supplied via the input connector and the key switch is in the off position. A pull-able circuit breaker should still be installed in the positive power wire.
The older Plasma II does not have this feature and must be turned on and off with a quality toggle switch."
There is an install manual section here:
http://www.lightspeedengineering.com...II_II+_III.htm
Section 2.8.A bullet 4 talks a little about key switches, and refers you to the input connector diagram (link to that in Section 2.9).
Not sure if that is what you need...I got a little lost looking at it, but I'm running toggles. Maybe someone actually using a key switch can press the "easy button" and have a simple explanation.
Hope this helps in the meantime!
Bob
