Old 03-06-2009, 08:44 PM
mattsmith mattsmith is offline
Default IO-360-A2B for RV-8A
I don't know what the A2B means. Will this engine work in a RV 8a? Thanks for yore time.
Old 03-06-2009, 11:18 PM
osxuser's Avatar
osxuser osxuser is offline
Yes, it should work fine. Same as the IO-360-A1A, but with a plugged crankshaft (FP prop as installed in a musketeer.)
RV4 wing in Jig @ KPOC
RV7 emp built
Old 03-06-2009, 11:47 PM
Default no C/S prop
So I wouldn't be able to run a constant speed prop? is there some where I can look up the definitions for varies lycomings? Thanks again for you're help.
Old 03-07-2009, 04:01 AM
penguin penguin is offline
Its not too difficult to convert FP to CS (google for the Lyc SB) - as long as the basic engine is capable, from Osxuser's post it seems this one will be. You will have to buy a governor drive adapter, a pipe and a bung or two.
Somewhere on the Lyc website is a description of what all the letters mean. There used to be a description sent out in the kit instruction book - if you don't have one find a builder nearby who has been building for several years.
Pete
Old 03-07-2009, 05:41 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
you can also go to faa.gov and pull all the AD's on the engine.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 03-07-2009, 04:05 PM
Transporter Transporter is offline
Default Engine Decoder
The Finish Kit portion of my plans has an engine chart (Chapter 11).
The IO-360-A2B decodes as:
200 hp @ 2700 rpm
100/100LL
8.70:1 compression
Bendix fuel injection, tuned induction
Fixed pitch
1200 series impulse magnetos
I can't tell from the chart whether or not the crank is hollow/solid...so don't know if it can be converted to constant speed.
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 03-07-2009, 07:29 PM
Default IO-360-A2B for RV 8A
Thanks for all your help. I have been looking on e-bay for the rite engine for the RV8A I am building and found this one. I like the option to go C/S so I don't know if this is it. Thanks again.
Old 03-07-2009, 08:59 PM
osxuser's Avatar
I used Wikipedia
http://en.wikipedia.org/wiki/List_of...O-360_variants
RV7 emp built
